Ga door naar hoofdinhoud
Removing Dell Inspiron 1150 RAM
Wat je nodig hebt
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: stap 1, afbeelding 1 van 1
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: stap 2, afbeelding 1 van 2 Removing Dell Inspiron 1150 RAM: stap 2, afbeelding 2 van 2
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: stap 3, afbeelding 1 van 3 Removing Dell Inspiron 1150 RAM: stap 3, afbeelding 2 van 3 Removing Dell Inspiron 1150 RAM: stap 3, afbeelding 3 van 3
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Conclusie
Christopher
8 Reputatie
1 Handleiding geschreven
Cal Poly, Team 16-2, Maness Spring 2010 Lid van Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 5,841
