Ga door naar hoofdinhoud
Removing Dell Inspiron 1150 Palm Rest
Wat je nodig hebt
  1. Removing Dell Inspiron 1150 Palm Rest, Removing Dell Inspiron 1150 Battery: stap 1, afbeelding 1 van 3 Removing Dell Inspiron 1150 Palm Rest, Removing Dell Inspiron 1150 Battery: stap 1, afbeelding 2 van 3 Removing Dell Inspiron 1150 Palm Rest, Removing Dell Inspiron 1150 Battery: stap 1, afbeelding 3 van 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Palm Rest, Hard Drive: stap 2, afbeelding 1 van 2 Removing Dell Inspiron 1150 Palm Rest, Hard Drive: stap 2, afbeelding 2 van 2
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. Removing Dell Inspiron 1150 Palm Rest, Optical Drive (Based on Dell Service Manual): stap 3, afbeelding 1 van 3 Removing Dell Inspiron 1150 Palm Rest, Optical Drive (Based on Dell Service Manual): stap 3, afbeelding 2 van 3 Removing Dell Inspiron 1150 Palm Rest, Optical Drive (Based on Dell Service Manual): stap 3, afbeelding 3 van 3
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. Removing Dell Inspiron 1150 Palm Rest, Keyboard: stap 4, afbeelding 1 van 3 Removing Dell Inspiron 1150 Palm Rest, Keyboard: stap 4, afbeelding 2 van 3 Removing Dell Inspiron 1150 Palm Rest, Keyboard: stap 4, afbeelding 3 van 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  5. Removing Dell Inspiron 1150 Palm Rest: stap 5, afbeelding 1 van 3 Removing Dell Inspiron 1150 Palm Rest: stap 5, afbeelding 2 van 3 Removing Dell Inspiron 1150 Palm Rest: stap 5, afbeelding 3 van 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  6. Removing Dell Inspiron 1150 Palm Rest, Display Assembly: stap 6, afbeelding 1 van 3 Removing Dell Inspiron 1150 Palm Rest, Display Assembly: stap 6, afbeelding 2 van 3 Removing Dell Inspiron 1150 Palm Rest, Display Assembly: stap 6, afbeelding 3 van 3
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  7. Removing Dell Inspiron 1150 Palm Rest: stap 7, afbeelding 1 van 3 Removing Dell Inspiron 1150 Palm Rest: stap 7, afbeelding 2 van 3 Removing Dell Inspiron 1150 Palm Rest: stap 7, afbeelding 3 van 3
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
  8. Removing Dell Inspiron 1150 Palm Rest, Removing Dell Inspiron 1150 Palm Rest: stap 8, afbeelding 1 van 2 Removing Dell Inspiron 1150 Palm Rest, Removing Dell Inspiron 1150 Palm Rest: stap 8, afbeelding 2 van 2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  9. Removing Dell Inspiron 1150 Palm Rest: stap 9, afbeelding 1 van 2 Removing Dell Inspiron 1150 Palm Rest: stap 9, afbeelding 2 van 2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
Conclusie
Teja
98 Reputatie
3 handleidingen geschreven
Cal Poly, Team 16-2, Maness Spring 2010 Lid van Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 6,947
