Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Position the computer upside down. Remove the twelve M2.5 x 8-mm screws.
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Position the computer keyboard side up. Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Locate the optical disk drive on the bottom left hand side of the laptop. Remove the single screw holding the optical disk drive in the chassis. Remove the optical disk drive by gently pulling on the outer edge.
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
Conclusie
Daniel
87 Reputatie
2 handleidingen geschreven
Cal Poly, Team 16-2, Maness Spring 2010 Lid van Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Leden
9 handleidingen geschreven
Één commentaar
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 21
Altijd: 5,703
