Inleiding
This guide will show you how to remove the back cover of your device.
Wat je nodig hebt
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
Bijna klaar!
Conclusie
