Ga door naar hoofdinhoud
Removing Canon PowerShot A550 Front and Back Covers
Wat je nodig hebt
  1. Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: stap 1, afbeelding 1 van 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: stap 1, afbeelding 2 van 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: stap 1, afbeelding 3 van 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Removing Canon PowerShot A550 Front and Back Covers: stap 2, afbeelding 1 van 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Removing Canon PowerShot A550 Front and Back Covers: stap 3, afbeelding 1 van 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Removing Canon PowerShot A550 Front and Back Covers: stap 4, afbeelding 1 van 2 Removing Canon PowerShot A550 Front and Back Covers: stap 4, afbeelding 2 van 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Removing Canon PowerShot A550 Front and Back Covers: stap 5, afbeelding 1 van 1
    • The camera should look like this once the front cover is removed.
  6. Removing Canon PowerShot A550 Front and Back Covers: stap 6, afbeelding 1 van 3 Removing Canon PowerShot A550 Front and Back Covers: stap 6, afbeelding 2 van 3 Removing Canon PowerShot A550 Front and Back Covers: stap 6, afbeelding 3 van 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Removing Canon PowerShot A550 Front and Back Covers: stap 7, afbeelding 1 van 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Shaelyn Thomas
332 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-6, Regan Spring 2011 Lid van Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Leden
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 4,227
