Inleiding
We will unscrew the bottom faceplate, then remove the base to access the internal components.
Wat je nodig hebt
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
10 andere personen hebben deze handleiding voltooid.
