Ga door naar hoofdinhoud
Removing 1985-1988 Volvo 740 Throttle Body
Wat je nodig hebt
  1. Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: stap 1, afbeelding 1 van 2 Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: stap 1, afbeelding 2 van 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Removing 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: stap 2, afbeelding 1 van 1
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Removing 1985-1988 Volvo 740 Throttle Body: stap 3, afbeelding 1 van 1
    • Locate throttle linkage cable assembly.
  4. Removing 1985-1988 Volvo 740 Throttle Body: stap 4, afbeelding 1 van 2 Removing 1985-1988 Volvo 740 Throttle Body: stap 4, afbeelding 2 van 2
    • Twist the assembly clockwise.
  5. Removing 1985-1988 Volvo 740 Throttle Body: stap 5, afbeelding 1 van 1
    • Slide both slackened cables off assembly’s guides.
  6. Removing 1985-1988 Volvo 740 Throttle Body: stap 6, afbeelding 1 van 2 Removing 1985-1988 Volvo 740 Throttle Body: stap 6, afbeelding 2 van 2
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Removing 1985-1988 Volvo 740 Throttle Body: stap 7, afbeelding 1 van 1
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Removing 1985-1988 Volvo 740 Throttle Body: stap 8, afbeelding 1 van 1
    • Remove the intake tube from the throttle body.
  9. Removing 1985-1988 Volvo 740 Throttle Body: stap 9, afbeelding 1 van 1
    • Locate wiring clip on the underside of the throttle body.
  10. Removing 1985-1988 Volvo 740 Throttle Body: stap 10, afbeelding 1 van 2 Removing 1985-1988 Volvo 740 Throttle Body: stap 10, afbeelding 2 van 2
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Removing 1985-1988 Volvo 740 Throttle Body: stap 11, afbeelding 1 van 3 Removing 1985-1988 Volvo 740 Throttle Body: stap 11, afbeelding 2 van 3 Removing 1985-1988 Volvo 740 Throttle Body: stap 11, afbeelding 3 van 3
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Removing 1985-1988 Volvo 740 Throttle Body: stap 12, afbeelding 1 van 3 Removing 1985-1988 Volvo 740 Throttle Body: stap 12, afbeelding 2 van 3 Removing 1985-1988 Volvo 740 Throttle Body: stap 12, afbeelding 3 van 3
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Removing 1985-1988 Volvo 740 Throttle Body: stap 13, afbeelding 1 van 1
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Raymond
76 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-28, Regan Fall 2010 Lid van Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 4,629
