Ga door naar hoofdinhoud
Removing factory feet from a Mac Laptop (Non-Retina)
Wat je nodig hebt
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: stap 1, afbeelding 1 van 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: stap 1, afbeelding 2 van 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: stap 2, afbeelding 1 van 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: stap 2, afbeelding 2 van 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: stap 2, afbeelding 3 van 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: stap 3, afbeelding 1 van 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: stap 3, afbeelding 2 van 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    iFixit Opening Picks (Set of 6)
    Koop
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: stap 4, afbeelding 1 van 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: stap 4, afbeelding 2 van 2
    Adhesive Cleanup Kit (Set of 12)
    Koop
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Nick
88.740 Reputatie
49 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.519 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 56
Altijd: 4,337
