Ga door naar hoofdinhoud
Inleiding
This guide shows how to separate the GameCube's optical drive assembly from the motherboard.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn over the Gamecube so that the bottom side is facing up. Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws. Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
  2. With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up. With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up. With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
  3. The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit. Do not detach the red and black cooling fan wire from the main unit.(red wire)
    • The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit.(red wire)
  4. Remove the four (4) Phillips #1 screws retaining the ground springs (outlined in teal). Carefully remove the ground springs from the main unit as shown in the second photograph.
    • Remove the four (4) Phillips #1 screws retaining the ground springs (outlined in teal).
    • Carefully remove the ground springs from the main unit as shown in the second photograph.
  5. The optical drive is secured to a metal plate. Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
  6. Carefully separate the optical drive assembly from the rest of the GameCube unit. The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly. The metal plate and the actual optical drive will remain attached (picture 3).
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached (picture 3).
Conclusie
dcarlin
295 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-2, Maness Fall 2009 Lid van Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Leden
34 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,311
