Inleiding
The brew unit is the central component of a coffee machine. It requires regular cleaning and maintenance, in particular the seals must be replaced from time to time. Unfortunately, the brew unit is at Jura and construction-type machines of e.g. Krups, AEG not easily accessible. The removal is described here.
The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
Remove the water reservoir.
Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
Slide the coffee funnel up and lift it out. It often sits very tight and you have to pull hard until it becomes free.
The screw on the top left must remain.
Remove the screw on the bottom left
remove the screw on the bottom right and the one in the middle right
Oke so I have a problem. I removed the screw marked blue, and now my machine makes a very weird noise when positioning for brewing. It sounds like a motor that’s somehow jammed. It moves up and down and actually makes a cup of coffee, however the grinds come out as a mud, rather then a puck. Any thoughts?
You did not disassemble the brewgroup? If so, the issue must be the screws. It' s no problem, if you opened the blue marked screw, it just holds both parts of the gear sledge together. I would remove the brew group again and control the sledge, the blue screw and the three remaining screws: one in the left below the blue one, and two in the lowest(!) holes on the right side. There are empty holes remaining! Turn the big wheel of the brewgroup and proof the function: does it move smoothie and easy? If you opened the brew group, my guess is a broken seal or some other issue.
The lower right screw is completely rusted and the T15 won’t turn it. There’s not enough room to get needle nose in there. Any thoughts on how to remove? I have a Z6.
Puuh, difficult. I never saw this before. (By the way: did you see this guide: Jura Z7 Brühgruppe austauschen). Perhaps it would help, if you first clean the head of the screw and then try to superglue the head of another srew or nail to it?
VauWeh -
Now the brew unitis free. Tilt it to the bottom but pay attention to the pressure hose. It must be led through an opening. Then push the brew group slightly downward to lift it out of the unit.
For further disassembly of the brew unit use this manual JURA Brewgroup Disassembly
Reverse the steps to reassemble your device.
(Note: if necessary, the oval screws can also be unscrewed with combination pliers and then replaced with others)
9 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
5 opmerkingen
The position is not very important. The distance between the big wheel and top may be about 4 cm. My guess is, that the position of your screws is wrong. Look at the pictures in step 7: the blue one is a machine screw and must not be removed. On the left side remains one screw (yellow) beyond the blue. On the right side are two screws (red), one near of the drainage valve and one above. In the upper region of the brewing unit are two empty holes, maybe you filled them?
bonjour j’ai bien nettoyé ma jura Impressa-F50-Pumpe e75 le groupe fonctionne parfaitement à la main mais se bloque en bas et en haut pendant la mise en place de la machine , pourtant j’ai changé le moteur et l’encodeur, que peut il se passer merci pour votre réponse cordialement
Dans ce cas, je devinerais l'encodeur. Mais s'il a déjà été échangé, est-ce peut-être l'électronique? C'est dommage.
VauWeh -
