Ga door naar hoofdinhoud
Remove IBM WorkPad c3 Battery
Wat je nodig hebt
  1. Remove IBM WorkPad c3 Battery, Back Case: stap 1, afbeelding 1 van 2 Remove IBM WorkPad c3 Battery, Back Case: stap 1, afbeelding 2 van 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Remove IBM WorkPad c3 Battery: stap 2, afbeelding 1 van 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Remove IBM WorkPad c3 Battery: stap 3, afbeelding 1 van 2 Remove IBM WorkPad c3 Battery: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  4. Remove IBM WorkPad c3 Battery, Battery: stap 4, afbeelding 1 van 1
    • Remove the yellow tape that is covering the battery connector
  5. Remove IBM WorkPad c3 Battery: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the tweezers, carefully disconnect the battery cable from the port
  6. Remove IBM WorkPad c3 Battery: stap 6, afbeelding 1 van 2 Remove IBM WorkPad c3 Battery: stap 6, afbeelding 2 van 2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emily Falkenstein
75 Reputatie
5 handleidingen geschreven
Cal Poly, Team 21-35, Regan Fall 2010 Lid van Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 33
Altijd: 4,241
