Ga door naar hoofdinhoud
Removal/Replacement of Dell Inspiron E1705 Hard Drive
Wat je nodig hebt
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: stap 2, afbeelding 1 van 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: stap 2, afbeelding 2 van 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: stap 3, afbeelding 1 van 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: stap 3, afbeelding 2 van 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: stap 4, afbeelding 1 van 1
    • Slide the hard drive tray out of the hard drive compartment.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Malik Shahbal
471 Reputatie
5 handleidingen geschreven
Cal Poly, Team 22-5, Maness Fall 2010 Lid van Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 32
Altijd: 20,451
