Ga door naar hoofdinhoud
Remington MB4040 Thermal Switch Replacement
Wat je nodig hebt
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: stap 1, afbeelding 1 van 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: stap 1, afbeelding 2 van 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: stap 1, afbeelding 3 van 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: stap 2, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: stap 2, afbeelding 2 van 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: stap 3, afbeelding 1 van 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: stap 3, afbeelding 2 van 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: stap 3, afbeelding 3 van 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): stap 4, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): stap 4, afbeelding 2 van 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: stap 5, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: stap 5, afbeelding 2 van 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: stap 6, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: stap 6, afbeelding 2 van 2
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: stap 7, afbeelding 1 van 1
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Cameron Carnahan
1.067 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-5, Blackwell Winter 2015 Lid van USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 2,855
