Ga door naar hoofdinhoud
Inleiding
Prerequisite Only
Onderdelen
Geen onderdelen opgegeven.
  1. Press the black button below the blade to remove the blade. Press the black button below the blade to remove the blade. Press the black button below the blade to remove the blade.
    • Press the black button below the blade to remove the blade.
  2. Place the device so the back of the product is facing up. Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Android Fix Kits
    A new screen or battery is one kit away.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  4. Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly. Remove the small clear plastic piece that covers the zoom wheel numbers. Remove the small clear plastic piece that covers the zoom wheel numbers.
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  5. Remove the two 16.0 mm PH00 screws from the front cover. Use the blue plastic opening tool to pry apart the two halves of the device.
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  6. Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves. The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
Conclusie
Cameron Carnahan
727 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-5, Blackwell Winter 2015 Lid van USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 53
