Ga door naar hoofdinhoud
Refresh, Reset, Start-up repair from USB recovery media
Video overzicht
  1. Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: stap 1, afbeelding 1 van 3 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: stap 1, afbeelding 2 van 3 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: stap 1, afbeelding 3 van 3
    • - Make Surface turned off and plugged in.
    • - Insert the USB recovery drive into the USB port.
    • - Press and hold the Volume Down button, press the Power button in a short time.
    • - When the Surface logo appears, release the Volume button.
    • - Select the language and keyboard layout.
    Where do I get the USB from?
    Soto Jaime - Antwoord
  2. Refresh, Reset, Start-up repair from USB recovery media: stap 2, afbeelding 1 van 3 Refresh, Reset, Start-up repair from USB recovery media: stap 2, afbeelding 2 van 3 Refresh, Reset, Start-up repair from USB recovery media: stap 2, afbeelding 3 van 3
    • Now you are in the Advanced Startup Options menu. You can choose from:
    • - Refresh your PC
    • - Reset your PC
    • ...or from Advanced options menu:
    • - Start-up repair
    • - Command prompt
    I tried downloading recovery image but some error while extracting it into the usb. Please help.
    Raj Patil - Antwoord
Conclusie
8 andere personen hebben deze handleiding voltooid.
ZFix
191.278 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
3 opmerkingen
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Muzahar - Antwoord
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Muzahar - Antwoord
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
pigi01se - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 5,576
