Ga door naar hoofdinhoud
Reemplazo de Tapa de Acceso iMac Intel 27" EMC 2429
Wat je nodig hebt
  1. Reemplazo de Tapa de Acceso iMac Intel 27" EMC 2429, Tapa de Acceso: stap 1, afbeelding 1 van 2 Reemplazo de Tapa de Acceso iMac Intel 27" EMC 2429, Tapa de Acceso: stap 1, afbeelding 2 van 2
    • Afloja los tres tornillos Phillips que sujetan la tapa de acceso al extremo inferior de tu iMac.
    • Estos tornillos permanecerán cautivos en la tapa de acceso.
    • Quita la tapa de acceso de tu iMac.
    • Durante el reensamblaje, cierra la tapa de acceso sin apretar y alíneala con la ranura en la caja externa del iMac antes de ajustar los tornillos completamente.
    I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
    Wizbang FL - Antwoord
    I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
    gordonhamachi - Antwoord
Conclusie
Para reensamblar tu dispositivo, sigue las instrucciones en sentido contrario.
24 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en es
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Phillip Takahashi
86.686 Reputatie
87 handleidingen geschreven
Één opmerking
Best ever guide! +)
Aleksei Marinichev - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 54
Altijd: 23,234
