Ga door naar hoofdinhoud
Redragon K552 Key Switch Replacement
Wat je nodig hebt
  1. Redragon K552 Key Switch Replacement, Key Switch: stap 1, afbeelding 1 van 3 Redragon K552 Key Switch Replacement, Key Switch: stap 1, afbeelding 2 van 3 Redragon K552 Key Switch Replacement, Key Switch: stap 1, afbeelding 3 van 3
    • Unplug the keyboard from the computer.
    • Because this keyboard does not use a detachable cable, you will have to detach the cable from the PC directly.
    • The location of the cable depends on how you had installed the keyboard into the PC. (In my case, I have it installed on the rear of my PC next to my ethernet cable).
    • RGB lights indicate that power is running through the keyboard.
    • Make sure that no power is running through the keyboard during the replacement process.
  2. Redragon K552 Key Switch Replacement: stap 2, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 2, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 2, afbeelding 3 van 3
    • Align the keycap puller to the keycap.
    • Use the keycap puller to pull out all the keycaps from the keyboard.
  3. Redragon K552 Key Switch Replacement: stap 3, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 3, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 3, afbeelding 3 van 3
    • Dip cotton swabs into a bottle of rubbing alcohol solution.
    • Clean the keycaps using the cotton swabs.
  4. Redragon K552 Key Switch Replacement: stap 4, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 4, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 4, afbeelding 3 van 3
    • Dip another cotton swab into the rubbing alcohol solution.
    • Carefully use the cotton swab to clean the surface and crevices of the keyboard.
    • Do not drop rubbing alcohol into the keyboard directly as it may cause damage to the keyboard.
  5. Redragon K552 Key Switch Replacement: stap 5, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 5, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 5, afbeelding 3 van 3
    • Align the switch puller with the faulty key switch.
    • Pull the faulty key switch straight up from the keyboard.
  6. Redragon K552 Key Switch Replacement: stap 6, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 6, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 6, afbeelding 3 van 3
    • Align the pins of the new switch to the keyboard.
    • Press the key switch on the keyboard until it clicks into place.
  7. Redragon K552 Key Switch Replacement: stap 7, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 7, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 7, afbeelding 3 van 3
    • Replace all of the keycaps.
  8. Redragon K552 Key Switch Replacement: stap 8, afbeelding 1 van 3 Redragon K552 Key Switch Replacement: stap 8, afbeelding 2 van 3 Redragon K552 Key Switch Replacement: stap 8, afbeelding 3 van 3
    • Plug the keyboard USB cable back to the PC.
    • Use a keyboard tester online to test your key switches.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Lyxander Blanco
187 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 6-2, Briggs Spring 2022 Lid van CSU Los Angeles, Team 6-2, Briggs Spring 2022
CSULA-BRIGGS-S22S6G2
1 Lid
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 134
Altijd: 6,524
