Ga door naar hoofdinhoud
RedOctane X-Plorer Whammy Bar Sensor Replacement
Wat je nodig hebt
  1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: stap 1, afbeelding 1 van 2 RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 2, afbeelding 1 van 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 2, afbeelding 2 van 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 3, afbeelding 1 van 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 3, afbeelding 2 van 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 3, afbeelding 3 van 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: stap 4, afbeelding 1 van 3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: stap 4, afbeelding 2 van 3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: stap 4, afbeelding 3 van 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 5, afbeelding 1 van 2 RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 5, afbeelding 2 van 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Sensor Replacement: stap 6, afbeelding 1 van 1
    • Using two hands, remove the whammy bar sensor.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Riley
649 Reputatie
7 handleidingen geschreven
Cal Poly, Team S17-G1, Livingston Spring 2018 Lid van Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 33
Altijd: 982
