Ga door naar hoofdinhoud
RedOctane X-Plorer Whammy Bar Replacement
Wat je nodig hebt
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: stap 1, afbeelding 1 van 2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: stap 2, afbeelding 1 van 3 RedOctane X-Plorer Whammy Bar Replacement: stap 2, afbeelding 2 van 3 RedOctane X-Plorer Whammy Bar Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: stap 3, afbeelding 1 van 3 RedOctane X-Plorer Whammy Bar Replacement: stap 3, afbeelding 2 van 3 RedOctane X-Plorer Whammy Bar Replacement: stap 3, afbeelding 3 van 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: stap 4, afbeelding 1 van 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: stap 4, afbeelding 2 van 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: stap 4, afbeelding 3 van 3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: stap 5, afbeelding 1 van 1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: stap 6, afbeelding 1 van 2 RedOctane X-Plorer Whammy Bar Replacement: stap 6, afbeelding 2 van 2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: stap 7, afbeelding 1 van 1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: stap 8, afbeelding 1 van 1
    • Using two hands, remove the spring from the plastic tabs.
Conclusie
3 andere personen hebben deze handleiding voltooid.
[deleted]
175 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 84
Altijd: 3,825
