Ga door naar hoofdinhoud
RedOctane X-Plorer Strum Bar Replacement
Wat je nodig hebt
  1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: stap 1, afbeelding 1 van 2 RedOctane X-Plorer Strum Bar Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Replacement: stap 2, afbeelding 1 van 3 RedOctane X-Plorer Strum Bar Replacement: stap 2, afbeelding 2 van 3 RedOctane X-Plorer Strum Bar Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Replacement: stap 3, afbeelding 1 van 3 RedOctane X-Plorer Strum Bar Replacement: stap 3, afbeelding 2 van 3 RedOctane X-Plorer Strum Bar Replacement: stap 3, afbeelding 3 van 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Replacement, Strum Bar: stap 4, afbeelding 1 van 1
    • Using two hands, gently remove the two string rod fixtures.
  5. RedOctane X-Plorer Strum Bar Replacement: stap 5, afbeelding 1 van 1
    • Lift up on the strum bar to remove it from the guitar.
  6. RedOctane X-Plorer Strum Bar Replacement: stap 6, afbeelding 1 van 2 RedOctane X-Plorer Strum Bar Replacement: stap 6, afbeelding 2 van 2
    • Remove the string rod by gently pulling it out of the strum bar.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jared McMullen
276 Reputatie
1 Handleiding geschreven
Cal Poly, Team S17-G1, Livingston Spring 2018 Lid van Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Leden
9 handleidingen geschreven
2 opmerkingen
This did not help.
michelle Coronel - Antwoord
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
Zachary Avery - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 49
Altijd: 3,672
