Ga door naar hoofdinhoud
RedOctane X-Plorer Motherboard Replacement
Wat je nodig hebt
  1. RedOctane X-Plorer Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 2 RedOctane X-Plorer Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Motherboard Replacement: stap 2, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement: stap 2, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Motherboard Replacement: stap 3, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement: stap 3, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: stap 4, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: stap 4, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: stap 4, afbeelding 3 van 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: stap 5, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: stap 5, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: stap 5, afbeelding 3 van 3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Motherboard Replacement, Keys: stap 6, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement, Keys: stap 6, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement, Keys: stap 6, afbeelding 3 van 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Motherboard Replacement: stap 8, afbeelding 1 van 2 RedOctane X-Plorer Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: stap 9, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: stap 9, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: stap 9, afbeelding 3 van 3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: stap 10, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: stap 10, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: stap 10, afbeelding 3 van 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Motherboard Replacement: stap 11, afbeelding 1 van 2 RedOctane X-Plorer Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Motherboard Replacement, Motherboard: stap 13, afbeelding 1 van 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: stap 13, afbeelding 2 van 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: stap 13, afbeelding 3 van 3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Riley
649 Reputatie
7 handleidingen geschreven
Cal Poly, Team S17-G1, Livingston Spring 2018 Lid van Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Leden
9 handleidingen geschreven
Één opmerking
Where can I but a replacement board?
Matthew - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 2,501
