Ga door naar hoofdinhoud
RedOctane X-Plorer Auxiliary Port Replacement
Wat je nodig hebt
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: stap 1, afbeelding 1 van 2 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: stap 2, afbeelding 1 van 3 RedOctane X-Plorer Auxiliary Port Replacement: stap 2, afbeelding 2 van 3 RedOctane X-Plorer Auxiliary Port Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: stap 3, afbeelding 1 van 3 RedOctane X-Plorer Auxiliary Port Replacement: stap 3, afbeelding 2 van 3 RedOctane X-Plorer Auxiliary Port Replacement: stap 3, afbeelding 3 van 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: stap 4, afbeelding 1 van 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: stap 4, afbeelding 2 van 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: stap 4, afbeelding 3 van 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
Conclusie
Riley
649 Reputatie
7 handleidingen geschreven
Cal Poly, Team S17-G1, Livingston Spring 2018 Lid van Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Leden
9 handleidingen geschreven
Één opmerking
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 1,201
