Ga door naar hoofdinhoud
Inleiding
This guide will lead you through the steps necessary to access the screen's components as well as how to assure it is properly connected.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip the device over
    • Flip the device over
  2. Unscrew the 2 screws closest to the screen
    • Unscrew the 2 screws closest to the screen
  3. Flip the device back over
    • Flip the device back over
    • It is now standing right side up
  4. Unscrew the top.
    • Unscrew the top.
  5. Take the top of the device off.
    • Take the top of the device off.
  6. Unscrew the button board.
    • Unscrew the button board.
  7. Take off the button board.
    • Take off the button board.
  8. Unscrew all visible screws on the black logic board cover.
    • Unscrew all visible screws on the black logic board cover.
  9. Lift the screen straight up out of the device.
    • Lift the screen straight up out of the device.
  10. Check that the single input plug from the logic board  to the screen (reverse side) is completely pushed in by pressing it firmly into the socket.
    • Check that the single input plug from the logic board to the screen (reverse side) is completely pushed in by pressing it firmly into the socket.
    • Also check that the 2 output plugs from the screen to the logic board are completely pushed in by pressing them firmly into the highlighted sockets.
    • You have successfully reconnected your display screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Sherman
31 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-50, Forte Fall 2012 Lid van Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 399
