Ga door naar hoofdinhoud
Reattaching the GEN 2 Wheelchair Foot Support
Wat je nodig hebt
  1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: stap 1, afbeelding 1 van 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: stap 1, afbeelding 2 van 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: stap 1, afbeelding 3 van 3
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Reattaching the GEN 2 Wheelchair Foot Support: stap 2, afbeelding 1 van 1
    • Screw in the bolt to the top socket to secure the height of the footrest.
  3. Reattaching the GEN 2 Wheelchair Foot Support: stap 3, afbeelding 1 van 2 Reattaching the GEN 2 Wheelchair Foot Support: stap 3, afbeelding 2 van 2
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
Conclusie
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
207 Reputatie
5 handleidingen geschreven
Cal Poly, Team 14-8, Maness Spring 2013 Lid van Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 801
