Ga door naar hoofdinhoud
Rear camera lens replacement for Samsung galaxy A 40
Wat je nodig hebt
  1. Rear camera lens replacement for Samsung galaxy A 40, Rear camera lens: stap 1, afbeelding 1 van 1
    • Your Galaxy A 40's lens is broken. Replace it in just a few minutes in order to make good quality images and videos again.
  2. Rear camera lens replacement for Samsung galaxy A 40: stap 2, afbeelding 1 van 1
    • Pull out the little glass shards and be sure not to damage or scratch the camera lenses just underneath.
  3. Rear camera lens replacement for Samsung galaxy A 40: stap 3, afbeelding 1 van 1
    • Pre-glue the new Samsung Galaxy A 40 rear camera lens with double-sided tape or two drops of B7000 glue.
    • Position this glass lens in its bracket using straight precision tweezers.
  4. Rear camera lens replacement for Samsung galaxy A 40: stap 4, afbeelding 1 van 1
    • Lightly press on the area to fix the lens.
    • Test your rear camera to confirm the quality of your photos and your videos.
    • If you are satisfied leave it to dry for an hour.
Conclusie
Bravo! You replaced the lens of your Samsung Galaxy A 40, clean the lens with a microfibre cloth. You can now take pictures and videos normally again.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
cPix
3.787 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 124
Altijd: 4,537
