Ga door naar hoofdinhoud
Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone
Wat je nodig hebt
  1. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone, Battery: stap 1, afbeelding 1 van 1
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
  2. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 2, afbeelding 1 van 1
    • Pop the back cover up using the groove on the top of the phone.
  3. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 3, afbeelding 1 van 1
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
  4. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone, Speaker or Camera: stap 4, afbeelding 1 van 2 Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone, Speaker or Camera: stap 4, afbeelding 2 van 2
    • Two rubber buttons cover the bottom two screws. Remove these rubber coverings to access the phone screws.
    • Using a T6 torx wrench, remove the four small screws at the top and bottom corners on the backside of the phone.
  5. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 5, afbeelding 1 van 1
    • Carefully pry off the faceplate using a spudger. Insert the spudger into the middle of the phone.
    • Start near a button and carefully work your way around the phone until the faceplate pops off.
  6. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 6, afbeelding 1 van 1
    • Remove the plastic and metal buttons located around the seam and place off to the side.
    • Be careful not to lose them!
  7. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 7, afbeelding 1 van 1
    • With a tweezer, pry off the back metal plate.
  8. Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 8, afbeelding 1 van 2 Reaching the Speaker and Camera in SONY Ericsson W890i Cell Phone: stap 8, afbeelding 2 van 2
    • The speaker and camera combo is accessible after the removal of two small #00 screws. Use the #00 Philips Screwdriver for this step.
    • The piece is now free to move from the phone core.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bob
316 Reputatie
3 handleidingen geschreven
SUNY Cortland, Team 1-3, Getto Spring 2013 Lid van SUNY Cortland, Team 1-3, Getto Spring 2013
SUNYCORT-GETTO-S13S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 809
