Inleiding
Use this guide to replace a damaged or broken charging port on a Razor Hovertrax 2.0. The charging port is located on the back of the unit and the side with the warning stickers about the product. For this guide you will need a Phillips #2 screwdriver and a 4mm hex screwdriver.
Wat je nodig hebt
Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
Bijna klaar!
Conclusie
