Ga door naar hoofdinhoud
Razor A Handle Grips Replacement
Wat je nodig hebt
  1. Razor A Handle Grips Replacement, Handle Grips: stap 1, afbeelding 1 van 2 Razor A Handle Grips Replacement, Handle Grips: stap 1, afbeelding 2 van 2
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: stap 2, afbeelding 1 van 2 Razor A Handle Grips Replacement: stap 2, afbeelding 2 van 2
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: stap 3, afbeelding 1 van 2 Razor A Handle Grips Replacement: stap 3, afbeelding 2 van 2
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Jordyn
544 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-13, Amido Fall 2012 Lid van Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Leden
10 handleidingen geschreven
Één opmerking
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 4,818
