Inleiding
If your Razer Wolverine Ultimate’s (model RZ06-225) analog sticks are not responding when you use them, there is a chance that there is something physically obstructing the movement of the stick. The analog sticks are meant to move game objects such as playable characters or the game camera. Prior to using this guide, try to update the controller’s firmware, use a different USB port, or clean the crevices with compressed air or a cotton swab and alcohol to see if that will fix the issue
Wat je nodig hebt
Place a Jimmy into the crevice between the front panel and one of the back grips, and gently pry the back grip off. Repeat for the other back grip.
