Ga door naar hoofdinhoud
Razer Ouroboros Lock Switch Replacement
Wat je nodig hebt
  1. Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: stap 1, afbeelding 1 van 2 Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: stap 1, afbeelding 2 van 2
    • Flip the mouse over and remove the stickers on the back of the device. These stickers are hiding the screws we need to remove.
    • Locate and remove the captive screws to remove the hand rest.
  2. Razer Ouroboros Lock Switch Replacement: stap 2, afbeelding 1 van 2 Razer Ouroboros Lock Switch Replacement: stap 2, afbeelding 2 van 2
    • Locate and remove the six 4mm screws on the back of the device.
    • Slide the side panels off the back of the mouse.
  3. Razer Ouroboros Lock Switch Replacement: stap 3, afbeelding 1 van 2 Razer Ouroboros Lock Switch Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using your tweezers, grab the trigger switch that you want to replace, and lift it from its slot.
    • If you have your replacement switch, place it in the newly freed slot and reassemble your device.
    • Note: the top guards of this mouse can come off now that the panel screws have been removed. Make sure these stay in place when reassembling.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Preston Darling
372 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 3,185
