Ga door naar hoofdinhoud
Razer Naga Expert MMO Top Plastic Shell Replacement
Wat je nodig hebt
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: stap 1, afbeelding 1 van 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: stap 3, afbeelding 1 van 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: stap 4, afbeelding 1 van 1
    • Lightly pull the two plastic sides of the mouse to remove them.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Gianni Conti
461 Reputatie
2 handleidingen geschreven
2 opmerkingen
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Antwoord
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 1,837
