Ga door naar hoofdinhoud
Inleiding
This guide will help you replace the motherboard which allows your mouse to function . Be sure to keep track of the 5mm screws and the 7mm screws.
Onderdelen
Geen onderdelen opgegeven.
  1. Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Remove the four 7mm screws using a Phillips #00 screwdriver.
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Gently remove the top plastic plate of the mouse.
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Lightly pull the two plastic sides of the mouse to remove them.
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  6. Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
    • Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
  7. Unplug the cord that connects the scroll wheel to the circuit board.
    • Unplug the cord that connects the scroll wheel to the circuit board.
  8. Slide the chip out of the scroll wheel.
    • Slide the chip out of the scroll wheel.
  9. Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse. Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
  10. Place the new scroll wheel in the mount.
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
  11. Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the circuit board to the main frame.
    • Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the circuit board to the main frame.
  12. Place the new motherboard in the mouse. When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
    • Place the new motherboard in the mouse.
    • When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacqueline Scalzo
238 Reputatie
2 handleidingen geschreven
Surprised this is rated Difficult. :f
Sumona Florence - Antwoord
Do you know where I can find the motherboard for the mouse?
aldo serrano - Antwoord
Where can I get a replacement motherboard?
David Mendo Diaz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 50
Altijd: 784
