Ga door naar hoofdinhoud
Razer Naga Expert MMO Cable Replacement
Wat je nodig hebt
  1. Razer Naga Expert MMO Cable Replacement, Top Plastic Shell: stap 1, afbeelding 1 van 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Cable Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Cable Replacement: stap 3, afbeelding 1 van 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Cable Replacement: stap 4, afbeelding 1 van 1
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Cable Replacement, Scroll Wheel: stap 5, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
  6. Razer Naga Expert MMO Cable Replacement: stap 6, afbeelding 1 van 1
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga Expert MMO Cable Replacement: stap 7, afbeelding 1 van 1
    • Slide the chip out of the scroll wheel.
  8. Razer Naga Expert MMO Cable Replacement: stap 8, afbeelding 1 van 2 Razer Naga Expert MMO Cable Replacement: stap 8, afbeelding 2 van 2
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
  9. Razer Naga Expert MMO Cable Replacement: stap 9, afbeelding 1 van 1
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
  10. Razer Naga Expert MMO Cable Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
  11. Razer Naga Expert MMO Cable Replacement: stap 11, afbeelding 1 van 2 Razer Naga Expert MMO Cable Replacement: stap 11, afbeelding 2 van 2
    • Place the new motherboard in the mouse.
    • When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
  12. Razer Naga Expert MMO Cable Replacement, Cable: stap 12, afbeelding 1 van 1
    • Once the motherboard is removed, pull the wire out of the plastic grooves on the bottom shell.
    • Then to completely detach the cable, unplug its white connection port from the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Gianni Conti
461 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 24
Altijd: 2,746
