Ga door naar hoofdinhoud
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement
Wat je nodig hebt
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement, Microphone Boom: stap 1, afbeelding 1 van 1
    • Remove the left ear cushion by rotating it counterclockwise as far as possible.
    • Pull the cushion upwards to remove it from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: stap 2, afbeelding 1 van 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: stap 2, afbeelding 2 van 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 6 mm screws around the speaker housing.
    • Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: stap 3, afbeelding 1 van 1
    • Remove the three 6 mm screws on the inside of the ear cup.
  4. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: stap 4, afbeelding 1 van 2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: stap 4, afbeelding 2 van 2
    • There are two wires going into the boom. One powers the LED lights and the other goes to the microphone. Each wire has two smaller ones in them.
    • Cut both wires, strip the shielding, solder the new wires together, and wrap them in electrical tape or use heat shrink. Be sure to insulate the wires from each other.
    • The two sets of wires are different colors, so you can figure out which wire powers the LEDs and which goes to the microphone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Samokyszyn
359 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 5-8, Lauer Spring 2014 Lid van Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Leden
13 handleidingen geschreven
3 opmerkingen
Ok, so where does one get a replacement boom mic?
stolensoulz79 - Antwoord
My classmate saw a pair of headphones on a
website today. He thought it was nice looking and good price. He asked me my
opinion. What do you think? Here is the link:
kobe - Antwoord
opinion. What do you think? Here is the link: http://menghu.ebcoo.net/product/original...
kobe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 2,676
