Ga door naar hoofdinhoud
Razer Huntsman Tournament Edition Port Replacement
Wat je nodig hebt
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: stap 1, afbeelding 1 van 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: stap 2, afbeelding 1 van 2 Razer Huntsman Tournament Edition Port Replacement: stap 2, afbeelding 2 van 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: stap 3, afbeelding 1 van 3 Razer Huntsman Tournament Edition Port Replacement: stap 3, afbeelding 2 van 3 Razer Huntsman Tournament Edition Port Replacement: stap 3, afbeelding 3 van 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: stap 4, afbeelding 1 van 1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: stap 5, afbeelding 1 van 2 Razer Huntsman Tournament Edition Port Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Port Replacement: stap 6, afbeelding 1 van 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: stap 7, afbeelding 1 van 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: stap 9, afbeelding 1 van 2 Razer Huntsman Tournament Edition Port Replacement, Port: stap 9, afbeelding 2 van 2
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: stap 10, afbeelding 1 van 1
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: stap 11, afbeelding 1 van 1
    • Remove the USB board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joseph O'Dowd
383 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Lid van UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Leden
7 handleidingen geschreven
Één opmerking
how do i get a new port and where
Guardian Suit - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 321
