Ga door naar hoofdinhoud
Razer DeathAdder Chroma USB Cable Replacement
Wat je nodig hebt
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma USB Cable Replacement: stap 2, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 2, afbeelding 2 van 2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma USB Cable Replacement: stap 3, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma USB Cable Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma USB Cable Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma USB Cable Replacement: stap 6, afbeelding 1 van 3 Razer DeathAdder Chroma USB Cable Replacement: stap 6, afbeelding 2 van 3 Razer DeathAdder Chroma USB Cable Replacement: stap 6, afbeelding 3 van 3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma USB Cable Replacement: stap 7, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: stap 8, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: stap 8, afbeelding 2 van 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma USB Cable Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma USB Cable Replacement: stap 10, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 10, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma USB Cable Replacement: stap 11, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma USB Cable Replacement: stap 12, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma USB Cable Replacement: stap 13, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 13, afbeelding 2 van 2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: stap 14, afbeelding 1 van 1
    • Locate the USB cable.
  15. Razer DeathAdder Chroma USB Cable Replacement: stap 15, afbeelding 1 van 2 Razer DeathAdder Chroma USB Cable Replacement: stap 15, afbeelding 2 van 2
    • Remove the USB cable by pulling it up and out.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Henry Shi
221 Reputatie
1 Handleiding geschreven
Baylor, Team S5-G2, Williams Spring 2017 Lid van Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 Leden
6 handleidingen geschreven
5 opmerkingen
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - Antwoord
Thanks for the advice
João Costa Santos -
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - Antwoord
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - Antwoord
where can i get the cable from?
Mourya Singham - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 14,684
