Inleiding
This guide outlines how to change the touchpad in the Razer Blade Stealth 2017. The touchpad breaking may be a result of a missing or out-of-date driver. Updating or reinstalling your touchpad drivers in Device Manager may help solve the problem. Some tools are required for this replacement.
Wat je nodig hebt
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a plastic spudger to gently undo the connections to the motherboard.
Use a Phillips #000 to remove all 55 1.6 mm screws from the metal plate.
Remove the metal plate from computer using your hands.
