Ga door naar hoofdinhoud
Razer Blade Stealth 2017 Speaker Replacement
Wat je nodig hebt
  1. Razer Blade Stealth 2017 Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Razer Blade Stealth 2017 Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Speaker Replacement: stap 3, afbeelding 1 van 2 Razer Blade Stealth 2017 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Speaker Replacement: stap 5, afbeelding 1 van 2 Razer Blade Stealth 2017 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Razer Blade Stealth 2017 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to disconnect the red and black speaker cables by lifting up on the pin-header.
    • The same process is used for both speaker connections.
    • Do not pull horizontally on the wires!
  7. Razer Blade Stealth 2017 Speaker Replacement: stap 7, afbeelding 1 van 2 Razer Blade Stealth 2017 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #00 to remove the two, 4mm screws on each speaker.
  8. Razer Blade Stealth 2017 Speaker Replacement: stap 8, afbeelding 1 van 3 Razer Blade Stealth 2017 Speaker Replacement: stap 8, afbeelding 2 van 3 Razer Blade Stealth 2017 Speaker Replacement: stap 8, afbeelding 3 van 3
    • Use a plastic spudger to pry the speaker(s) away from the chassis.
    • The speakers are glued to the chassis, making them difficult to remove.
    • The same process is used for both speakers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Helene Willits
765 Reputatie
6 handleidingen geschreven
Cal Poly, Team S11-G3, Regan Fall 2019 Lid van Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 1,114
