Ga door naar hoofdinhoud
Razer Blade Stealth 2017 HDMI and USB-A Port Replacement
Wat je nodig hebt
  1. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, Battery: stap 1, afbeelding 1 van 2 Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 3, afbeelding 1 van 2 Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 3, afbeelding 2 van 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 5, afbeelding 1 van 2 Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 5, afbeelding 2 van 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, HDMI and USB-A Port: stap 6, afbeelding 1 van 2 Razer Blade Stealth 2017 HDMI and USB-A Port Replacement, HDMI and USB-A Port: stap 6, afbeelding 2 van 2
    • Use a plastic spudger to lift up the press-fit interconnect cable and expose the USB-A and HDMI port module.
  7. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 7, afbeelding 1 van 2 Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  8. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 8, afbeelding 1 van 2 Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and HDMI port module.
  9. Razer Blade Stealth 2017 HDMI and USB-A Port Replacement: stap 9, afbeelding 1 van 1
    • Use a plastic spudger to remove the USB-A and HDMI port module from the case.
    • Do not damage the interconnect cable during removal!
Conclusie
Helene Willits
765 Reputatie
6 handleidingen geschreven
Cal Poly, Team S11-G3, Regan Fall 2019 Lid van Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,129
