Inleiding
The RAM or random access memory in your Razer Blade Stealth 2016 (Model # RZ09-01682E20) is a type of memory that stores working data and possibly machine code, in a short term memory. If your RAM fails then this can significantly slow down your computer. This guide will show you how to remove and replace the RAM in your Razor Blade Stealth 2016.
WARNING: The soldering iron gets very hot, so be cautious while using it.
Wat je nodig hebt
Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
