Ga door naar hoofdinhoud
Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement
Wat je nodig hebt
  1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 2, afbeelding 1 van 2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: stap 4, afbeelding 1 van 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: stap 4, afbeelding 2 van 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: stap 4, afbeelding 3 van 3
    • Carefully remove the auxiliary and main wire from the Killer 1535 wireless card.
  5. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 5, afbeelding 1 van 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 5, afbeelding 2 van 3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the two 2.61 mm screw holding the card in place.
  6. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 6, afbeelding 1 van 2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the card.
Conclusie
Kaitlyn Murray
239 Reputatie
1 Handleiding geschreven
USF Tampa, Team S1-G4, Leahy Fall 2019 Lid van USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 948
