Ga door naar hoofdinhoud
Razer Blade Stealth 2016 Keyboard Replacement
Wat je nodig hebt
  1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Keyboard Replacement: stap 2, afbeelding 1 van 2 Razer Blade Stealth 2016 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Keyboard Replacement: stap 7, afbeelding 1 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 7, afbeelding 2 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: stap 9, afbeelding 2 van 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: stap 9, afbeelding 3 van 3
    • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
    • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
    • This is how the tabs look in the flipped up position.
  10. Razer Blade Stealth 2016 Keyboard Replacement: stap 10, afbeelding 1 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 10, afbeelding 2 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Pull the cables out gently.
  11. Razer Blade Stealth 2016 Keyboard Replacement: stap 11, afbeelding 1 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 11, afbeelding 2 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 11, afbeelding 3 van 3
    • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
    • 5 screw locations are highlighted but locate all 55 screws and remove them.
  12. Razer Blade Stealth 2016 Keyboard Replacement: stap 12, afbeelding 1 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 12, afbeelding 2 van 3 Razer Blade Stealth 2016 Keyboard Replacement: stap 12, afbeelding 3 van 3
    • Remove the keyboard from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 845
