Ga door naar hoofdinhoud
Razer Blade Stealth 2016 Hard Drive Replacement
Wat je nodig hebt
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Razer Blade Stealth 2016 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Razer Blade Stealth 2016 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Carefully slide the hard drive out from its slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lindsay Grant
403 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Fall 2019 Lid van USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 38
Altijd: 3,034
