Inleiding
The purpose of computer fans is to cool down the device. As the computer is operating, the device produces heat. The fans will bring cooler air in to cool down the device. The fans are meant to cool the device down, if this part fails to do this, the computer could shutdown and need a reboot. If your fans in your Razer Blade Stealth 2016 isn't working properly, this guide will show you how to remove and replace the fans.
Wat je nodig hebt
Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
I’m trying to figure out how to attach the ribbons to the motherboard.
Are the two fans the same?
