Ga door naar hoofdinhoud
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
Wat je nodig hebt
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: stap 1, afbeelding 1 van 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: stap 2, afbeelding 1 van 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: stap 2, afbeelding 2 van 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: stap 3, afbeelding 1 van 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: stap 3, afbeelding 2 van 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: stap 3, afbeelding 3 van 3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: stap 4, afbeelding 1 van 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: stap 5, afbeelding 1 van 1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Conclusie
Carson Kellerman
495 Reputatie
4 handleidingen geschreven
Cal Poly, Team S18-G1, White Winter 2020 Lid van Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Leden
6 handleidingen geschreven
Één opmerking
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 25
Altijd: 2,171
