Ga door naar hoofdinhoud
Inleiding
The main reason you would want to replace the speakers in your laptop would be that they are faulty and not producing sound. Another might be that you just want to upgrade to a better speaker. The speakers in this device are located on the outer left and right sides of the motherboard. The speakers dimensions are 1 x 1.75.
Onderdelen
Geen onderdelen opgegeven.
  1. Using a Torx T5 screwdriver, remove the ten 1/8 inch screws.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws.
  2. Using a Phillips #0 screwdriver, remove the two screws holding down the speaker. Using a Phillips #0 screwdriver, remove the two screws holding down the speaker.
    • Using a Phillips #0 screwdriver, remove the two screws holding down the speaker.
  3. PC Laptop batterijen
    An easy fix for a big power boost.
    Nu winkelen
    Nu winkelen
  4. Disconnect the wire by pinching with your fingers and pulling up.
    • Disconnect the wire by pinching with your fingers and pulling up.
  5. Remove the speaker.
    • Remove the speaker.
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 6
Altijd: 82
