Inleiding
Use this guide to remove or replace the back cover on your Razer Blade 15" (2020) laptop.
Wat je nodig hebt
Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
