Ga door naar hoofdinhoud
Razer BlackWidow Chroma Wire Harness Replacement
Wat je nodig hebt
  1. Razer BlackWidow Chroma Wire Harness Replacement, Rubber Feet: stap 1, afbeelding 1 van 2 Razer BlackWidow Chroma Wire Harness Replacement, Rubber Feet: stap 1, afbeelding 2 van 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer BlackWidow Chroma Wire Harness Replacement, Front Panel: stap 2, afbeelding 1 van 2 Razer BlackWidow Chroma Wire Harness Replacement, Front Panel: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer BlackWidow Chroma Wire Harness Replacement, Wire Harness: stap 3, afbeelding 1 van 1
    • Using a Philips #1 screwdriver, remove all ten screws found on the edges of the keyboard.
    • Two of the screws are found on either side of the main cable.
  4. Razer BlackWidow Chroma Wire Harness Replacement: stap 4, afbeelding 1 van 2 Razer BlackWidow Chroma Wire Harness Replacement: stap 4, afbeelding 2 van 2
    • Remove the wire harness.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 1,732
