Ga door naar hoofdinhoud
Razer Basilisk V3 Backplate Replacement
Wat je nodig hebt
  1. Razer Basilisk V3 Backplate Replacement, Skates: stap 1, afbeelding 1 van 1
    • Locate each of the skates.
  2. Razer Basilisk V3 Backplate Replacement: stap 2, afbeelding 1 van 3 Razer Basilisk V3 Backplate Replacement: stap 2, afbeelding 2 van 3 Razer Basilisk V3 Backplate Replacement: stap 2, afbeelding 3 van 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Backplate Replacement, Backplate: stap 3, afbeelding 1 van 1
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Backplate Replacement: stap 4, afbeelding 1 van 3 Razer Basilisk V3 Backplate Replacement: stap 4, afbeelding 2 van 3 Razer Basilisk V3 Backplate Replacement: stap 4, afbeelding 3 van 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Backplate Replacement: stap 5, afbeelding 1 van 3 Razer Basilisk V3 Backplate Replacement: stap 5, afbeelding 2 van 3 Razer Basilisk V3 Backplate Replacement: stap 5, afbeelding 3 van 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
Conclusie
Brendin Costa
402 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-2, Santin Spring 2024 Lid van UMass Dartmouth, Team 1-2, Santin Spring 2024
UMASSD-SANTIN-S24S1G2
3 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 227
Altijd: 1,055
