Ga door naar hoofdinhoud
Razer Barracuda X Motherboard Replacement
Wat je nodig hebt
  1. Razer Barracuda X Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Razer Barracuda X Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Remove the cushion by pulling it off from the edge and out from the grooves, Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Motherboard Replacement: stap 2, afbeelding 1 van 3 Razer Barracuda X Motherboard Replacement: stap 2, afbeelding 2 van 3 Razer Barracuda X Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver to unscrew the four screws that attach the two pieces of the right speaker together.
    • Gently lift the plastic plate away from the housing, with care not to damage the connected wire.
  3. Razer Barracuda X Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the single screw attaching the volume spinner to the motherboard.
    • Remove the spinner.
  4. Razer Barracuda X Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the Phillips #0 screws securing the I/O board from the bottom shell of the right speaker.
  5. Razer Barracuda X Motherboard Replacement: stap 5, afbeelding 1 van 2 Razer Barracuda X Motherboard Replacement: stap 5, afbeelding 2 van 2
    • To fully remove the I/O board from the right speaker, use tweezers to unplug the ribbon cable attaching the I/O board to the main motherboard.
  6. Razer Barracuda X Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Using the same Philips #0 screwdriver, remove the four screws attaching the motherboard to the plastic housing. Once those screws are removed, remove the main motherboard and replace it.
Conclusie
Josiah Cassidy
241 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
4 Leden
7 handleidingen geschreven
3 opmerkingen
Now if I could just find somewhere to buy the I/O board. My volume slider is crackling and sometimes one cup is louder than the other.
Michael Nugent - Antwoord
You ever find a replacement?
Gaelan Garrett -
@michaelnugent My volume wheel just broke too! Must be a weak point in the design.
Michael Shu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 218
Altijd: 2,456
